I have backed up two of my dvd's but when i play the backups in my dvd player they work...but...the dvd player kinda vibrates and im worried it might break it or something. whats up with this? anyone?![]()
I have had this problem with cheaper media. What brand disc are you using for your backups?
4x Datawrite disks (Datesafe media)
Can it break the dvd player? and what should i do to resolve the problem?
Make sure you don't put label on the disks. The placement of the labels (especially on VCD/SVCD) disks can cause balance problams and YES the spindle vibration will eventually cause problems.
I returned 2 APEX DVD players for the same problem. They vibrated even with commercial pressed DVD's.Only 3 things are certain in life... Death, Taxes, and SPAM. Of these, only Death seems affordable!
SVCDummy -
Well hey thats what you get for buying an APEXOriginally Posted by SVCDummy
. Buy Sony. Quality japanese product.
quality Japanese product would be from Pioneer.Originally Posted by g_shocker182
Sony DVD players have notorious format compatibility problems....lots don't play SVCDs...but some have been able to use VCD header trick to play SVCDs...but that takes extra work that shouldn't be needed in the first place.
Hi8 to PC, video vibrating (Video comparisons)
By smashwings in forum Capturing and VCRReplies: 6Last Post: 3rd Apr 2012, 10:00 -
Need codes to convert Australian DVD player into a multi region DVD player
By Seajacb123 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Oct 2010, 01:00 -
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 12:55 -
my player blu ray disk samsung bd-p 1400 not player my avchd on dvd-rw !?
By LEONESVIZZERO in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Apr 2008, 09:15 -
How Can I Convert Real Player Video Files To Make Them DVD Player Compatabl
By Lennoxtown in forum Video ConversionReplies: 8Last Post: 17th Oct 2007, 06:05
