I ripped the video from a dvd+r i made, opened into tmpgenc- but what bitrate do i use to keep it exactly the same as the source? all i want to is to clip the video, not change bitrates/sizes etc. Whtever I seem to choose I Cannot get it to be the same size as my original.
Is there a program that you can use with video and ac3 to cut out adverts?
k ill look into that, but ny help on the other question
I used SP on my DVD recorder to record 100minutes video to disc. max is 120mins of SP. on the disc it says 3.6gb, i used avicodec and it says its 7500bitrate 720*576 and 25fps, i set that in tmpgenc and i get an estimated file size of 5814.86. Why cant i just clip the video without having to encode
Is there a program to edit HDDVD like Clown_BD can edit Blu-ray?
By c627627 in forum Authoring (Blu-ray)Replies: 0Last Post: 3rd Jan 2011, 23:35 -
Edit, add, extract WAVE and edit file tags with new Machete 3.5
By MacheteSoft in forum Latest Video NewsReplies: 0Last Post: 23rd Dec 2009, 10:05 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
trying to edit ac3 bitrate of mkv
By dgizzy in forum Newbie / General discussionsReplies: 8Last Post: 11th Dec 2008, 14:14 -
need help in choosing a format after video edit (DV then edit then DVD)
By shade_2 in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2008, 13:13
