why dont you five dvd2svcd a try. It is located at www.dvd2svcd.org. It is free. The only app that you needs is an encoder (tmpgenc,cce,or procorder). There are a few guides out there that show you how to convert, but the interface is pretty easy to figure out.
Here is what you do., depending on what you want (remembering the cant polish a turd analogy), in misc tab, change it to avi and make the mpeg 2 or 1 depending if you are going to vcd or cvd or svcd or dvd. check the advanced tab(this will give you access to change the resolution size) on frameserver tab, change the resolution to whatever it is, it is suppose to be, downsample the audio in the audio tab (VCD). set up the encode tab and whatnot. and click go. should take about 2 hours on a 1.2 gig machine.
Results 31 to 37 of 37
Originally Posted by TarbiSam Ontario
Originally Posted by macleodSam Ontario
I'm using TMPG to convert my avi files to dvd so they may be put onto dvd-r to be watched on a player? My problem is that after i convert, the new file peoples faces and clothing have a slight blue tint to them. If anyone knows why this is like that please help? Thanks
Sammer, you need to go to Newbie Conversion and open up a new thread. Not that you do not have a good question, but what you are doing is called hijacking a thread. It is against forum policy, and what is worse, if Tgpo finds what you have done, he will wear his bikini to your next fancy dinner party. So what, you say? I said the same thing, and when he did it to me, my wife cried for three days, and I still get nightmares...
Hello. -
I hate when ppl title the threads "HELP ME!!!" or "URGENT!!!" or even "URGENT!!! Help me!!!" cuz that's just dumb. I can't figure out if I should go in from the title. It should tell me atleast one program you're using and some part of your problem.
keyboard help urgent
By dnmnbg in forum ComputerReplies: 2Last Post: 3rd Apr 2012, 21:45 -
AVStoDvd Help, urgent
By DaneClark in forum Authoring (DVD)Replies: 1Last Post: 21st Oct 2010, 20:22 -
Software help, URGENT
By ianbeddow in forum EditingReplies: 4Last Post: 6th Aug 2010, 04:23 -
messenger urgent help!
By alintatoc in forum ComputerReplies: 2Last Post: 1st Jun 2009, 09:39 -
Urgent computer help
By Seasonal in forum ComputerReplies: 24Last Post: 23rd Jul 2008, 02:49
