I have coded a xVCD with this resolution: 544 x 480
When I try to play it in my Stand Alone DVD Player, the DVD Player switches to NTSC mode but when I coded the movie I set it 25 fps is 544 x 480 a NTSC resolution ??
What is the resolution between 352 x 288 and 720 x 576 that can be used as a PAL compatible xVCD.
Thank You
Luis Pinho
Vertical resolution should be 288 or 576. Horizontal resolution depends on your player. I played succesfull 352x288, 352x576, 480x576, 720x288, 720x576.
DVD resolution is 720 x 480 ??
By siratfus in forum Video ConversionReplies: 6Last Post: 3rd Mar 2013, 09:47 -
Is PAL 576 Higher Resolution Than NTSC 480?
By wulf109 in forum DVD RippingReplies: 12Last Post: 1st Dec 2011, 01:10 -
DVP 5990 and 852 x 480 Resolution
By Wanderlustus in forum DVD & Blu-ray PlayersReplies: 6Last Post: 4th Nov 2009, 12:29 -
Will a blu ray disk play on regular dvd player in 480 lines of resolution?
By donfm in forum Newbie / General discussionsReplies: 5Last Post: 6th Jan 2009, 06:00 -
Newbie question about 720 x 480 dvd resolution
By siratfus in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2008, 17:30
