I would like someone to explain how, or preferably point me to a guide which shows me how to join 2 DVD's together keeping menu's extra features and everything else without having to demultiplex the video's.
Results 1 to 10 of 10
Joining 2 DVD's while keeping menu's extra features and everything else:
Software you will need:
DVDdecrypter
DVD2One
Vobedit
IfoEdit
Burning Program of your choice
1.Rip 1st disc with DVD Decrypter (all the files) to a folder.
2.Run the 1st disc through DVD2One choosing a total ouput files size of about 2.2 gigs and the "full disk" option.
3.Rip the 2nd disc with DVD Decrypter (all the files) to a separate folder than that of the 1st disc.
4.Run the 2nd disc through DVD2One choosing a total output files size of about 2.2 gigs and the "full disk" option.
5.Now go here http://ifoedit.wh.fr0zen.com/joinclip.html#joindbl and follow the instructions carefully on “Joining double sided DVDs”
Disregard steps 1 & 2 regarding IfoEdit and follow these:
1.Once you have ALL the VOBS together and in one single directory (this is where you should be if you followed the above instructions) you should have something similar to the below:
VTS_01_1.VOB
VTS_01_2.VOB
VTS_01_3.VOB
VTS_01_4.VOB
VTS_01_5.VOB
VTS_01_6.VOB
Notice I have deleted all the IFO and BUP files.
2.Open IfoEdit and click “Create IFOS”. Select the first VOB (VTS_01_1.VOB) in your final folder and click ok.
3.Once complete, in IfoEdit again click “Open” and select the VTS_01_0.IFO file that IfoEdit just created.
4.Now click “Get VTS Sectors” and select “Yes” through all the prompts. It is VERY important that this step be completed.
5.Done authoring. Now burn with your program of choice.
_________________Live Long, Play Hard, Think BIG! -
Thanks for all your bother, kpoman, I appreciate it. I'll try it out today. One last thing kpoman, it is not two double sided DVD's that I am trying to join, it is a dual layer and single layer. Does this matter?
@ vance43211, I had originally tried your guide, several times, but what happens is I get all the menu's and everything else, but when I click on a menu item, no matter what it is, it always goes to the same video, so I can only select different videos (even from the same DVD originally) by selecting different titles using my DVD player.
vance 43211, if I am doing something wrong to make this happen whilst using your guide, could you please give me some pointers to correct it.
EDIT:: Sorry, kpoman, I am so stupidI just realised that with the link to joining the double sided DVD I am supposed to act like I am joining a double sided DVD and make the single layer disc the first side, and make the dual layer disc the second side. This is right, isn't it?
Just tried the guide kpoman. The only problem is that I can keep everything APART from the menu's (in IFOEdit it says that there is a menu in the files and that I should delete it and re-run the get VTS Sector function). I don't know what I'm doing wrong, please help me if you can.
Thanks in advance, pixel. -
you will have to drop your menus and do movie only
https://www.videohelp.com/forum/viewtopic.php?p=581464&highlight=#581464 -
Originally Posted by vance43211
It was just really for something watchable with easy navigation, but I guess there is no easy way, unless I can be bothered demultiplexing all the streams and creating a menu structure as near to the original as possible using DVDMaestro. -
pixel, it is possible to do with the menu, but you have to be fluent in IFO edit language, and its really hard to explain the linking of titles to the menu, the addion of chapters and their pointers. If you have the time (And a sh*t load of patients) you could do it with ifoedit.
Originally Posted by dicktheprick
I would have the patience to try out a guide to keep the menu. If you have a link to a guide that will help me to do it I would really appreciate it.
If you don't and have to type out a whole load of instructions, don't bother, because I wouldn't want to waste your time unless you were very willing to help me. -
Originally Posted by pixel
the effort will not be worth it
i kinda understand how to do it that way
but it is seriously complicated and too long to explain
it's easier to make a dvd with just the menu on it -
Thanks for everyone's help in this post,
pixel.
Full Screen Ripped DVD is not Displaying Full Screen on Widescreen TV
By jgciamarra in forum DVD RippingReplies: 3Last Post: 23rd Jan 2012, 17:42 -
Windows Media Player 8 full screen DVD playback not full screen
By brassplyer in forum Software PlayingReplies: 1Last Post: 3rd Jan 2012, 15:43 -
External Hard Drives...How Full Is Too Full?
By bbanderic in forum Newbie / General discussionsReplies: 5Last Post: 17th Mar 2010, 17:25 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 17:46 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 18:14
