hi all
Can someone kindly explain me the feature "closed caption (line 21)"
and the practical use of it
Thanks to everyone who can help.
Shaul
I don't know what program you're talking about, but it sounds like this could be a feature to convert DVD subtitles into regular closed captioning.
Closed captions are enbedded into NTSC video signals using line 21 of the vertical interval (there are approx 40 lines in the vertical interval; if you ever see a black bar at the top of the screen with white dots moving; that's the vertical interval).
If you tell us the name of the program and where you see this, we may be able to help you further. -
I think the Closed Caption format is for NTSC only. I believe that Teletext is used for PAL. I could be wrong though.
non-linear,
you are correct. NTSC has line21 closed-captions while PAL has the more advanced, but unfortunately higher bandwidth teletext. It's high enough and complex enough that it was considered too complex for DVD's consumer hardware when the spec was formalized. Therefore, PAL just uses DVD-formatted subtitle/subpictures.
Maestro, BTW, doesn't do subtitle-->closed-caption conversion, if that's what you were thinking. It does accept line21 data as a specifically formatted text file IIRC.
How can I show subtitles on the the top line and on the bottom line.
By Dracko in forum Authoring (DVD)Replies: 14Last Post: 8th May 2014, 15:03 -
RF Modulator with S-video line-in or composite line-in?
By Disco Makberto in forum RestorationReplies: 30Last Post: 24th May 2009, 16:11 -
i bought 3 movies on line but they don't download they play from on-line
By N8DOGB4000 in forum Video Streaming DownloadingReplies: 6Last Post: 10th May 2008, 17:20 -
Extracting Closed Caption and writing it back to mpeg as open caption
By CBiLL in forum Newbie / General discussionsReplies: 1Last Post: 30th Aug 2007, 03:50 -
I can see my caption but not save it.
By pegee in forum Capturing and VCRReplies: 0Last Post: 25th Jul 2007, 16:06
