Hi
I was using CCE 2.5 to make a rip of the matrix and it encoded fine using single pass VBR the projected time was 16 hours which was odd because usually the rips r half that!
I let it go on for 1/2 hour then stopped it and i saw that the MPEG file had a VERY wierd glitch!
The movie played fine but every now and again it would repeat a scene 2 or 3 times (i dont mean the player jumps back and replays the scene i mean the scene was actually encoded numerous times)i used 1 pass VBR at min 1600 max 1500 Q 65 and then i had the complexity slider thing on 25 and the interlacer on 6!
Why did this happen?
someone please help!!!!
thanx
ed
Go get smartRipper (Tools link at left) and rip the DVD again - you ripped all of the multiple angles together, so when you encode, you get them all - SmartRipper will pick the "standard" angle for you and rip only that one, which will give you a much better encode.
hey
not thats not the problem....i set DVD decrypter to NOT rip multi-angles so thats not the problem!
thanx
ed
Subtitle Glitch
By KingMisfit in forum Video ConversionReplies: 2Last Post: 8th Jan 2012, 13:46 -
Is this a VH glitch of some kind ?
By Seeker47 in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2009, 14:09 -
imgburn 2.4.4 glitch
By johns0 in forum ComputerReplies: 23Last Post: 15th Jun 2009, 02:25 -
ZUNE 30 Software Glitch
By Number Six in forum Portable VideoReplies: 6Last Post: 1st Jan 2009, 15:40 -
Controlling CCE's output file size.
By astrocity20 in forum DVD RippingReplies: 24Last Post: 13th Dec 2007, 23:32
