I am encoding DV AVI files with TMPGE, the DV file is Type 1 and TMPGE loads it ok and encodes ok but there is a little quality loss with the encoding. I find constant 2520 bitrate gives me the best quality video and sound. I tried 2-pass VBR and I think the video quality was less and the sound was not so good.
My question is, when I encode DVD to SVCD I seem to recall changing the sound settings to a lower amount maybe 44 or less can't remember as I now use DVDTOSVCD for DVD disks. Can I free up some bitrate by changing my DV 1 file to DV 2 file and then resampling the sound to a lower figure thus giving me a bit more bitrate for the video?
I can get VERY good quality from DVD to SVCD using DVDTOSVCD and wondered why I am lossing some with my DV files. The DV file played direct from cam to tv is acceptional. The burned SVCD of my DV file is good but does not seem as good as dvd to svcd and yet the DV source is of great quality.
Back to the top one more time! Am I way off in left field here?
Swing a hammer at it, if it doesn't fix it I gaurantee you will feel better.
Jittery movement on encoded file (Bitrate setting question)
By cb678 in forum ffmpegX general discussionReplies: 4Last Post: 5th Nov 2011, 14:30 -
How to determine if a mkv / avi / whatever file is constant or avg bitrate?
By smackyourfupa in forum Newbie / General discussionsReplies: 3Last Post: 8th Oct 2011, 05:26 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 15:01 -
Bitrate of avi file and x264 file
By maass in forum Newbie / General discussionsReplies: 8Last Post: 9th Apr 2009, 07:27 -
Bitrate question for Avi to Wmv conversion w/ Windows Media Encoder
By Gonz0ne in forum Video ConversionReplies: 5Last Post: 6th Jan 2008, 08:19
