Hi, I have been haveing a problem for ever now. I can't burn vcds out of mpeg files. I run a imac, and use toast 5. When ever I put mpeg file into the toast program I get a message that says the file can't be used, because "it contanes a mpeg data in an unsuported format".
Well I have never found a mpeg file that will work. How ever I can get avi files to work. Avi files seem to be the only kind of files I can encode to vcd format.
Also I was reading through this mac forum, and heard people say to use tmpeg and virtual dub. What good does that do on a mac? Is there a tmpeg and virtual dub program for mac?
Anyways, I still don't get why I can't use any mpeg files to make a vcd, can anyone help with that?
sup
if toast doesn't accept your mpg is because they're not VCD compliant. To convert them to compliant mpgs you have different options :
If your MPG is totally out of compliance you need to re-encode it with:
- Cleaner 5 (on mac) and convert to "MPG-1 Video CD"; or
- TMPGenc (on PC, or Virtual PC; there is no mac version)
If your MPG is near compliant you can try VCDGear with MPG->MPG conversion and the Toast compliant option, or use TMPGenc to demux and remux to MPG-1 VCD. -
hmmm cleaner 5 eh? (I don't have virtural PC)
(goes of to find that)
THANK Y OU!
(I'm not afraid or long converson times)
*drools at the thought have haveing anime music videos on vcd*
*drools some more*
Thank you!
2 Cameras, lots of problems.
By Benhermies in forum EditingReplies: 2Last Post: 12th May 2009, 12:01 -
[SUPER] iPod on TV conversion problems (heavier and lots of squares)
By Horrigan in forum Video ConversionReplies: 9Last Post: 24th Mar 2009, 23:02 -
Lots of problems that transcends different sections.
By guy_edwin in forum Newbie / General discussionsReplies: 4Last Post: 20th Dec 2008, 04:36 -
Archiving lots of DV
By nsdn in forum Video ConversionReplies: 6Last Post: 14th Oct 2007, 12:07 -
Daytek DVR-P30: lots of 'fails' when erasing, lots of nothing when recordin
By buzzinhornets in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Jul 2007, 15:43
