Hi there!
It seems there has been a mistake while updating my Supervision 2500 firmware, and the player don't work anymore (it doesn't even power up!). Do you know any method to recover my firmware? I've downloaded the old version, but since the player doesn't power up I can't work it out. Is there a method to reset my player to factory settings?
Thanks!
other than asking the manufacturer for a download of the original version and borrowing an EPROM burner from someone, you're probably out of luck
all i can say is i'm glad i read this as i have the same model and was thinking of updating.. but as it seems to work mostly fine as it is (if a little inflexible) i think i'll leave it well alone. what was the update supposed to do?-= She sez there's ants in the carpet, dirty little monsters! =-
Back after a long time away, mainly because I now need to start making up vidcapped DVDRs for work and I haven't a clue where to start any more!
Need BluRay player that does what Philips 2500/2700 does,but sells in USA
By ufcdave in forum DVD & Blu-ray PlayersReplies: 2Last Post: 22nd Feb 2011, 22:41 -
anyone know how to unlock denon dvd-2500 regions
By similar in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Jan 2011, 15:03 -
I just bought an expensive laptop - was it a $2500 mistake?
By Eat Right in forum ComputerReplies: 35Last Post: 18th Nov 2009, 13:33 -
Tool for VCD at 2500 bitrate with No Re-encoding
By whenloverageswild in forum Authoring (VCD/SVCD)Replies: 21Last Post: 6th Mar 2009, 12:34 -
DVD shrink is only encoding @ 2500 KB/s or so? Instead of the 12000KB/s?
By Denvers Dawgs in forum DVD RippingReplies: 6Last Post: 29th Jun 2008, 11:23
