I'm having fun reading your posts, some people fire nero because it's buggy and make coasters,
one bug (for me it's not a big bug because you have a warning message) and this is the worst soft ever made.
So don't use windows![]()
For those who use the root directory as a temp folder : this is a big big mistake. Nero wipe the directory if you don't pay attention, you've find this bug because you use nero, some other softwares do . Just try under dos : format c: or del c:\*.* you will have a warning message and if you agree you've wiped your disk.
Of course, they can patch the soft, but computers are not as simple. If you are not careful, you can do foolish things.
My advice : read all the windows appearing on your screens and try to understand the consequences if you answear yes or no
Results 31 to 37 of 37
This is a kind of interesting discussion re Nero's failings (but defense, could you please stop ranting, it ain't helping anyone).
I picked up a comment that Nerovision Express just doesn't work, but then someone else suggested it worked fine.
The only thing I've tried to use it for, writing a pic slideshow to a VDC, failed utterly, even when I tried writing ti to an image recorder. I do not have the MPEG" encoder plug in, (I'll wait till the prog works at all, first, beofore paying for it) but I shouldn't need that for mpeg 1, for VCD.
It crashes out every time.
I upgraded to Nero 6 because I had been happy with Nero 5, 5.5 etc. However I'm not so happy now. The Smartstart thing is a pain in the bum, and I might dump it. Wave editor has most of the options missing, so you can't actually edit, and has been commented, Nerovison don't work.
I've dumped the Nero Media player, as it had managed to disable Windows media player, so I could no longer just whack in a music CD and play it. I didn't want to use the Nero player for music, as every time I change a track, it asks if I want to delete the previous playlist. Damn annoying.
I'm OK with the DVD player thing, so far, and Nero itself seems fine.
Apart from that I'm happy........William -
Originally Posted by defense
Nero 6 needs work.
I love Nero 5.5 and I'm a big supporter of Ahead.
But Nero 6?
They should know better. I think their beta testers need replacing.Want my help? Ask here! (not via PM!)
Originally Posted by daredevil
Does it seem firing? NicW was just being objective.
And don't get me wrong, I got Nero5.5.10.42 and RecordNow DX installed, and I use them both.
I'll be waiting till Nero6 gets fixed about ten times and maybe upgrade then. -
I've been using Nero and Easy CD Creator for sometime now. My fav is Nero... more control. Hey, opinions differ. But as far as verion 6's go... EZCD is the better of the two. BTW, software will always have bugs. Its just a matter of deciding which ones you can live with. This one in Nero 6 however is unacceptable. If you've got a version of any burning software and it works for you, works for your burner... no need to shell out hard earned beer money and upgrade.
One other note about Nero 6... I tried the demo and found it a bit to 'intrusive'. It installed everywhere! Didn't seem like I could pick what I wanted to install or NOT install. Oh well, shouldn't expect much from a demo.Swift Kick In The Butt $1.00
"Everybody I know needs what I'm selling!" - Calvin -
NICW
for your thorough report
I'll wait and check out STOMPS backup program instead
by the way did anyone use WIN ON CD 5?
it says it does DVD PREMASTERING...what's that as relates to burning? -
dcsos
Don't forget to install the pxengine update so Backup MyPC can deal with DVD media
http://support.sonic.com/Downloads/engine.asp
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 19:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 18:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 13:42 -
Hard-Drive write caching,Is my hard drive faulty
By jezzer in forum ComputerReplies: 33Last Post: 27th Sep 2008, 11:06 -
Hard drive got wiped on XP reinstall???
By dimtim in forum ComputerReplies: 14Last Post: 6th Aug 2007, 13:49
