is there something albeitly wrong with joining two avi files, when ever i do it i either get a movie where the voices speed up and down every sop often, or when its complete a file that saysits done but only has the first half of the movie...whats up with that?....holla back
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"? -
Sounds like VBR audio to me.
To merge 2 files, they must have:
1) The same codec/codec version for video
2) Exactly same FPS (29.970 and 27.971 are not the same, this applies to captures mainly)
3) Same Audio codec for both
4) Same Audio bitrate for both (VBR may join, may not)
5) Video's msut be exactly the same resolutions
6) Headers must match exactly (you can specify a DivX file several ways, depending on codec version and encoding software, use GSPOT)To Be, Or, Not To Be, That, Is The Gazorgan Plan -
stupid repl, but does virtual allow you to join avi files in its program......holla back
Yes under file, append avi.
joining avi files
By dugen in forum MacReplies: 1Last Post: 11th Jun 2011, 12:47 -
Joining avi files
By carlmart in forum Video ConversionReplies: 13Last Post: 29th May 2009, 07:35 -
Joining AVI files
By nycdude in forum EditingReplies: 6Last Post: 20th May 2009, 23:03 -
Joining avi files?
By tofuguy in forum EditingReplies: 4Last Post: 7th Oct 2008, 02:30 -
Joining avi files?
By t_jay17 in forum EditingReplies: 5Last Post: 18th Dec 2007, 12:22
