  1. greetings,
    i am thinking about buying that dvd player, because of some good reviews, and his abillity to play nearly everything, because i have everything... that's my problem though... i have a RCE DVD, some kind of new search for hacked dvd players... does anyone know, if i make the player region free, or set it to one region, if i still can play those dvds?
    i would be happy for every answer...
  2. You can change region code using remote between 2 and 1 and a couple of others, plays them fine have not come across any dvd it wont play at the moment, it can be a bit fussy with some types of DVDR+/+RW but that does go across the board with most players it depends on the manufactuer you will have to trial them. Apart from that a good solid player.
