I got some movies which i have extract from cdi or bin image, and when i tried to play the dat. file i have extracted it doesn't work. With media player is said class not registered and with WinDvd, it has sound but no picture. I pretty sure those files is should work. So is should be something wrong with the player. I tried install mpg 2 codec still doesn't work. Can anyone help
thanks
You didn't extract the movie just the DAT file from the bin image. There is actally a slight difference between teh DAT file and the MPEG1 file it was authored from. That's why people use VCDGear and other programs to conert their VCDs back to MPEGs.
With that said I suspect that you are trying to open the dat file from within WMP. This often doesn't work (esp in winXP). You need to run windows explorer, right click on the dat file, choose open with, then choose WMP.
Re-naming the file to *.mpg will also work 95%+ of the time -
yea but WinDvd suppose to work because the program can player dvd or vcd format right, and dat file is vcd format, but when i play it, there no picture just sound and the sound is not properly too
Problem playing file in Media Player.
By hanugro in forum Newbie / General discussionsReplies: 13Last Post: 29th Apr 2011, 20:13 -
Playing subtitles off VOB file in Media Player Classic
By aduh11 in forum Newbie / General discussionsReplies: 2Last Post: 27th Dec 2009, 14:44 -
Problem playing a .mov file with Media Player Classic - No audio
By shiningwizard in forum Software PlayingReplies: 4Last Post: 20th Sep 2008, 06:52 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 22:49 -
Revised Question: Problem playing joined file on windows media player
By Johnny_Blaze in forum Newbie / General discussionsReplies: 1Last Post: 15th May 2007, 12:25
