I have a problem with converting a NTSC video (29.970 fps) to Pal. I converted the video just fine, frameserving with VirtualDub, and encoding the video with TMPGenc. Then I do the audio with BeSweet, convert it NTSC->Pal, and then multiplex it.
The video is then perfectly in sync, but the audio sounds very slow, like in slow-motion, and the voices are very low. What should I do???
Lily
Results 1 to 9 of 9
You can use a program such as Cool Edit Pro or Soundforge to do the audio stretching. They have options whereby you can preserve the original pitch of the audio. They're not perfect, but there are various equalisations you can pick (eg speech would be the best for a movie), and they're gonna be better than nothing...
Originally Posted by cjp49
HEY!
Since you did it using TMPGEnc, you may have not said Do not framerate conversion. Since this is probably the case, just encode using BeSweet without the framerate conversion filter. -
Thanks you guys for the replies, but I have just found out that I didn't need to convert it to PAL, because my dvd-player can play both ntsc and pal VCDs. But thanks anyway.
Lily -
What you probably did was convert from 30 fps to
25 fps including the audio.
What you should do is IVTC the video to restore it
to 24 fps FILM and change Frame rate to 25.
That will make it play slightly fast instead of extremely slow.
how to slow down interlaced Ntsc recording of Pal ?
By spiritgumm in forum Video ConversionReplies: 20Last Post: 11th Oct 2010, 19:59 -
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 15:17 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19 -
Audio Slow after NTSC>PAL...?
By nbarzgar in forum AudioReplies: 7Last Post: 19th Feb 2008, 09:39
