the program does have a small sync error but it continues,
the problem is it gets to step 4 and stops,it dosent tell me its finished and it somehow hasnt created the video_ts folder.
all i have is a file called XXXX_dvd_mpg
this does play in power dvd but is this file a dvd file and how do i burn it ?
handymanGuest
handymanGuest
its version 1.1 and the patching video stream sequence headers
process is step4
settings i used r: in\out mpg>es
horiz rez patch 352 entire file
help. -
Version 1.1 that is the svcd2dvdmpg (not +) version i think and that doesn't make video_ts folder only mpgs you need to author the mpgs yourself with an author program like tmpgenc dvd author or dvd lab. If you want svcd2dvdmpg to do it all the you need to buy svcd2dvdmpg+
Greatings,
Yf
Not Responding and what is the ! about?
By Wicked_T in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 10th Sep 2010, 17:44 -
Samsung SH-S203N SATA DVD Burner stops responding during burns?
By 1wheelken in forum DVD & Blu-ray WritersReplies: 84Last Post: 24th Aug 2009, 14:30 -
(not responding) problems
By pjcom in forum EditingReplies: 1Last Post: 9th Jul 2008, 12:36 -
HDD Not Responding Correctly
By RKelly in forum ComputerReplies: 7Last Post: 29th Jan 2008, 23:03 -
Toast Titanium not responding....then it does
By SonicMix in forum MacReplies: 5Last Post: 5th Sep 2007, 14:59
