i have just downloaded ken park in xvid and installed the codec but everybody is blue
how do i fix this
I was encoding some VHS material a while back using XviD and noticed these weird purple "stains" when playing back some of the files. I was using ffdshow for XviD decoding, so i went into the options-screen and checked the "use XviD" box, after that everything worked like a charm. The XviD codec i have installed is uManiac's stable build dated 24.02.2003.
i install ffdshow and it does the same to all my other movies and when i test it in gspot it says it is fine and that it should play
You need the newest version of the codec, or latest FFDShow.
To Be, Or, Not To Be, That, Is The Gazorgan Plan
XIVD cannot output video with MP3 audio
By pchan in forum Video ConversionReplies: 6Last Post: 25th Sep 2009, 10:51 -
Camcorder changes original colours
By marklewis in forum Capturing and VCRReplies: 2Last Post: 31st Mar 2009, 12:40 -
colours are weird?
By bennyboyt in forum Newbie / General discussionsReplies: 5Last Post: 23rd Dec 2007, 19:47 -
movie with Xivd fomat!!!
By dewolf in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2007, 19:55 -
Avi Or Mpeg to Xivd/Divx
By Castor troy in forum Video ConversionReplies: 2Last Post: 27th May 2007, 10:24
