  1. Member nick101181's Avatar
    Sep 2000
    Toronto, Canuck Country
    Lately when I try burning sevcd's or anything at 4x I get a buffer underrun error. This is very annoying. It has only started doing it recently. I have 866 megahertz and 128 SDRAM, windows ME. I know that if you do a lot of stuff at a time it will give you that error, but I make sure I always close stuff out and not do anything else when I burn cd's. This always works fine before, why did it start now? Should I get new drivers,use a cd-rom cleaner,...what? thanks
    Jan 2001
    Vancouver/Portland
    Trying burning @ 2x instead of 4x. And if that don't work, 1x never fails =|
  3. I Don't think SeVCD is the cause, but you might want to try installing your IDE (or SCSI) drivers again incase they got curropted, I would also suggest you try reinstalling the ASPI Layer and make sure it's the latest, it might fix your problem with the Buffer Underrun.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
