  1. I recently bought a DV camcorder. I've installed a firewire card which Windows XP can see & says is working OK.
    When I try to capture using Ulead Movie Factory 2, I'm getting a message "cannot connect capture driver". I've tried MGI Videowave 5, but that can't see it either.
    I've tried different cables & moving the firewire card to a seperate port, but nothings working.
    The camera's a JVC GR-DX25
    Any ideas?
    Dec 2002
    New Hampshire
    Have you checked the preferences to see what Ulead is trying to use for capture? It sounds almost like it is trying to use VFW capture drive.... I had to manually change the prefences for my brother in laws machine the other day. He is using VS 5... But I bet it's the same problem..
  3. I'm a bit of a newbie at this, can you clarify please?
    Dec 2002
    New Hampshire
    When you run the Ulead application, Look for the prefrences settings and see what it is set to for a capture device. I'm not in front of a computer running Ulead now so I can't exactly remember where it is found. But you could always use the ulead help and search it for settings and capture device. Sorry I can't be of more assistance..
    Windows to get a job, Unix to rape clients for $$$, MS BoB for MCM (Mac Cult Members) Mac's for my Toddler to play games on and Linux for the rest of us!
    The difference between genius and stupidity is genius has limits. A. Einstien
  5. Thanks for the advice. I've tried the camera on another PC & still no joy, I think there's a problem with the DV Out on the camera itself. I'm going to have to get it replaced.
