I seem to have problems with ripping DVDs on my system(XP). I am using DVD Decrypter and have been able to do a few. I have also used Smartripper but the same problems have come up. After about 80% of the process it starts to have problems with reading sectors. Is there anything that I am overlooking????
Try using a different program like smartripper, if the problems still persist you can divert your attention towards the disc and the drive itself.
Thats a good point but it happens in the last 20% of ripping. I have been successful with 1 but I keep having problems with the programs reading sectors.
Try a different DVD ROM Drive in your system. I've found some DVD RoMs to be old and develop optical read problems. Just another suggestion. The process of elimination, hardware/software.
I have given that thought, the DVD rom is pretty new(about 5 months old) but would it make any difference since it is a combo drive. This problem is very irritating because I was able to back up Harry Potter successfully but am unable to do any others. Im sure the answer will be the simple one but until then I will pull out hair.The combo drive I am using is:
Philips CDD5301
cdrw 32x 10x rewrite
40x read
dvd 12x
Problems ripping Precious
By carlos28355 in forum Blu-ray RippingReplies: 7Last Post: 16th Jun 2010, 21:54 -
Problems ripping my DVD
By KayAt in forum Newbie / General discussionsReplies: 2Last Post: 11th Feb 2009, 17:33 -
Ripping Problems
By pepegot1 in forum DVD & Blu-ray WritersReplies: 4Last Post: 23rd May 2008, 09:15 -
Problems ripping this...
By EliteMarine in forum DVD RippingReplies: 7Last Post: 29th Apr 2008, 23:18 -
Having ripping problems
By ezzye23 in forum DVD RippingReplies: 3Last Post: 25th Jun 2007, 13:30
