Hi guys !
I'd like to know if the "OK" button on the DVD player remote control can be define with VCDEasy. Can you help me ??
Thank you !![]()
I don't know what DVD player you own. Is the 'OK' button the same as 'ENTER' button on most DVD player? That is, is this the button that you use to select the menu option? If that is the case, then "you can map this button in VCDEasy as the 'DEFAULT' button.
*** My computer can beat me at chess, but is no match when it comes to kick-boxing. ***
TMPGenc Authoring Works 4 - How do I set the "first button" on a menu?
By silentmachine in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2011, 08:05 -
"Full Screen" button not working properly
By ironjack in forum Newbie / General discussionsReplies: 2Last Post: 14th Aug 2010, 20:20 -
Using DVDLabPro to create a "sound effect" button?
By takearushfan in forum Authoring (DVD)Replies: 7Last Post: 1st Jun 2010, 20:53 -
Question about secret hidden "Back" button in Gui For DVD Author
By jimdagys in forum Authoring (DVD)Replies: 2Last Post: 15th Dec 2008, 04:17 -
Re: making "live" chapter button with windvd creator 2
By tomcat862 in forum Authoring (DVD)Replies: 0Last Post: 28th Feb 2008, 13:13
