Trying to use CCE to convert from Divx to SVCD, but came up on a snag that I don't really know how to fix.
I am following the guide given here as close as I can. The problem comes up after I try to add my .VDR file to the CCE window.
It comes up with an error:
"According to the registry, the type of file specified in AVIFileOpen does not have a handler to process it."
I have no idea what this means, which is why I place it here and ask if anyone has an answer how to fix this.
The issue that may be causing this is that the source file seems to be PAL framerate (25fps) as I checked it in File information in Virtual Dub.
Which brings up another problem. If I am to encode this, should I stick with this CCE process till I figure it out?
Or should I run with the TMPGenc method outlined on this site? And should I stick with the PAL framerate or should I try and convert within TMPGenc or some other method?
I have an APEX 1500 Standalone player, and according to most, it seems to run PAL with the least problems, though I have yet to try it out.
So if anyone could answer these questions for me, I'd greatly appreciate it.
And 1 more thing:
When I load the source file into Vdub, it comes up with a frame size of 576 X 240
Which if I am not mistaken, is not proper PAL frame size.
PAL to DVD Converting using CCE: Lanczos not resizing video!
By dianita in forum Video ConversionReplies: 5Last Post: 12th Dec 2009, 01:12 -
CCE Pal to Ntsc conversion-NO AUDIO
By ranosb in forum Video ConversionReplies: 9Last Post: 2nd May 2009, 05:45 -
CCE guide for PAL to NTSC conversion
By alexs_eu in forum Video ConversionReplies: 9Last Post: 21st Jun 2008, 07:41 -
Pal to NTSC with CCE?
By Sephiroth666 in forum Newbie / General discussionsReplies: 4Last Post: 28th Dec 2007, 22:45 -
CCE VS DivX
By SteveF22 in forum Authoring (DVD)Replies: 9Last Post: 25th Aug 2007, 20:13
