I have a Sony DRU-510A housed in an external USB 2.0 case. Has anybody tried to flash the firmware over the USB connection? Or should I play it safe and remove the drive from the external case and attach it to an IDE connector to flash the firmware?
All replies are appreciated, but I would especially like to hear from those with real experience doing this. The risks is too great to rely on theoretical answers or speculation! Thanks.
i think so, you can flash it in a firewire case which is almost the same thing.
I have flashed my Memorex external drive through firewire several times.
I know its not the Sony you asked for but since nobody answered.... -
Thanks for your replies. I'll give it a go, unless someone posts a negative experience!
DRU-500 in external USB flashed no prob.
The USB or Firewire chipset acts just like a standard IDE controller, you should be fine.
External usb/sata case for dvd or bluray drive
By Haopengyou in forum Media Center PC / MediaCentersReplies: 4Last Post: 3rd May 2011, 17:54 -
Which hdtv's have a USB port, so you can plug in a flash drive or USB HDD?
By snafubaby in forum DVB / IPTVReplies: 8Last Post: 30th Nov 2010, 17:03 -
USB Powered external case for 3.5" Hard Drives....
By siratfus in forum ComputerReplies: 7Last Post: 11th Jan 2009, 07:14 -
External case - 3.5 or 5.25 case....
By kenmo in forum ComputerReplies: 3Last Post: 2nd Jan 2009, 16:54 -
dvd player +dvix+usb with external 160GB external HD problem...
By spidermen in forum Newbie / General discussionsReplies: 14Last Post: 14th Oct 2008, 20:45
