I know that there is a tutorial on here to convert RM to AVI, and I'm not sure if you can go backwards with the tutorial, but I was wondering if anyone knew how to convert AVI to a streaming format, whether it be RM or WMP. I not only would like to put my DV caps on disc, but I would also like to stream them from the web.
First and foremost, however, I would like to compress the AVI (if, that is, it does not compress as you are converting to a streaming format) as the AVI's that I captured from my DV cam are huge (e.g. 92MB AVI is only 25 seconds in length!)!
I have seen some sites with a streaming format ".mpa" which is a variation of ".mpg" which streams in quicktime, so that may be an option.
Please advise.
Thanx.
<font size=-1>[ This Message was edited by: bachelor on 2001-09-29 14:59:30 ]</font>
Results 1 to 1 of 1
Streaming MPEG2-TS files to WMP 11 (XP)
By Penumbra in forum Video Streaming DownloadingReplies: 0Last Post: 2nd Apr 2010, 16:39 -
Shuffle play streaming links in WMP
By JohnnyOh in forum ProgrammingReplies: 0Last Post: 31st Dec 2009, 01:33 -
Optimal Settings for WMP Streaming Video
By john_doe1 in forum Video Streaming DownloadingReplies: 9Last Post: 24th Sep 2009, 18:12 -
ADPCM Format ? WMP refuses to play
By drwho in forum AudioReplies: 2Last Post: 30th Oct 2008, 23:28 -
Convert from FCP output (DV-PAL) to a format playable on PC in WMP
By Ferry99 in forum Video ConversionReplies: 1Last Post: 24th Dec 2007, 19:32
