hi, this is my first post, i am a total newbie and i need to know how to get video off my video camera and onto my harddrive. i have a p4 1.7 Ghz. 128 mb RDRAM and i have a 60 gb hd for progams and i am going to get a 120 gb hd for the videos, the camera we have has a port for a dv plug to fit in how do i get the video from the camera to HD and what programs do i use. i Just want to know exactly what is going to happen before i buy anything. i was told that the ADS Pyro Capture card is a good one to start with. i currently do not want to burn the video onto discs rather i only want to store them on HD.
thank you
You need a Firewire card (Not a capture card). Anyone will do.
Use DVIO to transfer the DV video through the firewire card to your HD.http://www.carr-engineering.com/dvio.htm
Then if you are going to store the videos, you need to compress them. DV video takes up alot of space otherwise.
I use VirtualDub with the DivX http://www.divx.com compressor, or the XviD http://www.xvid.org compressor.
And MP3 for the audio on the videos.
When you do decide to burn the videos they will be playable on any DivX certified MPEG-4 player device. -
You need a firewire card (1394)
$40 at bestbuy:
http://www.bestbuy.com/site/olspage.jsp?id=1051384643521&skuId=5179889&type=product&pr...oryId=cat01077
$25 online (free shipping, just add something for a $1)
http://www.ecost.com/ecost/shop/detail.asp?dpno=138542
WindowsXP moviemaker does OK to import the DV media -
will any firewire card work? is the Pyro one better? what software do i use? someone mentioned Ulead Video Studio 7?
I think any firewire card should do the job ok- It might be worth looking around for one that has both firewire and usb2- for later on. Otherwise, see if anybody is offering something like a DV starter kit- with the card, cables and some software to use. I bought one and it had Ulead videostudio5 in it- an old version but it still worked ok.
You do get MovieMaker2 for free with WindowsXP, but if you do not like
it you could get this combo for $99
http://www.bestbuy.com/site/olspage.jsp?id=1051384505547&skuId=4686799&type=product
Combining synched sound with video - total absolute newbie
By Povster in forum Newbie / General discussionsReplies: 2Last Post: 24th Mar 2011, 17:37 -
Total newbie needs help urgently (AVDHC -> DVD, with complications)!
By sebkni in forum Newbie / General discussionsReplies: 0Last Post: 17th May 2010, 14:11 -
total newbie dvd converting burning
By mujin in forum Newbie / General discussionsReplies: 6Last Post: 29th Jan 2009, 12:28 -
Advice for a total Newbie
By Lawman1965 in forum Newbie / General discussionsReplies: 1Last Post: 25th May 2008, 13:24 -
newbie - getting video stream from ip camera
By kevineaton in forum Newbie / General discussionsReplies: 3Last Post: 14th Feb 2008, 13:40
