  1. What are the easiest ways to rip and burn a DVD, free is a plus. Any and all tutorials you have will help me out a bunch.
    Jon
  2. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    you'll find those guides over on the left under "How To: DVD Rip"
    if it's a single layer dvd, the easiest method is to rip as an ISO with DVD Decrypter, which will burn the ISO to a fresh disc, and is freeware.
    dual layer, you have to decide what you are willing to give up - extras / menus / multiple audio tracks etc. or some quality.
    read the guides.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
  3. I second using DVD Decrypter.
    You can tell if its a single layer by going to "My Computer" and if when you select the drive the DVD is in it will say 4.38Gbs or less. If double layer, >4.38. Hope this helps.
    Jan 2002
    Not the end of the world!
    And if it's over 4.38 gigs. You can download a free program called DVDShrink which will transcode the files down to a size which will fit on a recordable dvd. Then burn the transcoded files with a trial version of Nero.
    All free!
  5. good overview guide of most of the proggies: https://www.videohelp.com/forum/userguides/141024
    DVDshrink guide...good stuff: http://www.doom9.org/index.html?/mpg/dvdshrink2-main.htm
    DVDshrink is:
    1) the fastest
    2) FREE
    3) but, not the best quality
