Results 1 to 20 of 20
  1. this dvd just came out, and i am able to rip it with smartripper, but i cant frameserve it correctly with DVD2AVI.
    it just stops at halfway through the process, DVD2AVI shows that this dvd has 2 vob cell ID's.
    did anyone rip this dvd to divx or vcd? if so, plz help.
    thx
  2. I ripped it with DVDDecryptor and transcoded it with DVD2one then burned it with Recordnow and it works fine.
  3. anyone got it ripped to (s)vcd or divx?
  4. DO you have Dr. DivX? I use that when I make DivX
    May 2003
    Iceland
    @ deh707
    I have had in the past a troubled DVD not sure what the name was but I had the same problem your running into so what I did was to use the vob's that d21 had produced and then use dvd2avi
    Just my 2cents.......
    Hope this helps
  6. He means DVD2one. There you go, use DVD2One and set the output file size high so that it doesnt compress, then the vob files it produces should work for you.
    Or DVDShrink if you dont have D21 and don't wanna spend the $$
  7. plz don't double post...
    anywayz, like i said in other post..i ripped to SVCD no probs....
    are you ripping in "movie mode" in smartripper?
  8. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    I tried to rip it and got seriously screwed up.
    ..of course it was a Best Buy that I tried to rip it from, and a security guard tackled me. The case poked me pretty hard in the ribs.
  9. oh, sorry for the double post.
    i ripped in file mode, what's movie mode going to do?
  10. Best Buy had it for $15.99, 2 disc set, so I just brought it. 8)
  11. Originally Posted by deh707
    1) "movie mode" automatically picks the main movie for you....it looks like you may not have ripped all the necessary files in "file mode"
    2) some DVDs have multi-angles in them...i.e. as part of a special feature where they show you the behind-the-scenes view of part of the movie....daredevil may have something similar..... "movie mode" will remove the multi-angles for you and just give you the main movie....if you rip in "file mode", you will have problems....(audio outta sync, behind-the-scenes instead of the actual movie, etc....)
    thus, use "movie mode" to rip.....
  12. Of course the real question here is why anyone would want to "backup" that crap movie (or purchase it in the first place).
    -v20
    "Did you see what GOD just did to us??" - Fear and Loathing in Las Vegas
  13. thanks, movie mode seemed to work.
    version20: Of course the real question here is why anyone would want to "backup" that crap movie (or purchase it in the first place).
    too see garner in action.
  14. Hey, Daredevil was o.k.! A Black Kingpin was a jip and some of the acting could have been better, but Collin Farrel was great as Bull'sEye and Jennifer Garner was totally hot! The action was really good too. As for ripping it, I've found Clad DVD.Net works on movies that Smartripper fails on. Matter of fact, CladDVD and CladDVD.Net (now it's a .NET program) has not failed me ever. Plus, it automatically frameserves after ripping with no user intervention. It's free too.
  15. Yeah Jennifer Garner makes it worth while
  16. I actually liked the movie, its the first time I ever saw Ben Affleck make an attempt at acting.
  17. dvd shrink no problem!
  18. I used Sefys guide for DVD>VCD. Worked perfect. Too perfect
  19. I just used DVDX Xpress to back it up.
