About a month ago my brother was in Iraq and I sent him some cds with movies on them. They were in Divx so I also sent him a divx player and codec. Well he installed them on some guys computer and the movies played fine, but since then he said the guys players wont play his dvds. I walked him through uninstalling the player and it still dosent work. He says that all of the player just lock up. Real, Microsoft and even WinDVD. The guy is pretty pissed and I was wondering if anyone had any ideas what went wrong. I also sent a Nimo Codec pack and I think he installed that too. Both of which has been uninstalled. But there are still problems.
I dont know what kind of computer it is, and for that matter I'm not even sure what OS it is. I'm pretty sure its Xp, if anyone could help I would appreciate it.
"Sleep-
Those little slices of Death;
How I loath them." -
Which DiVx program did you send him? Sometimes DivX comes with some real shady adware and codecs that can mess with your system. Try looking in the system tools and see what wierd codecs DiVx have been installed.
Also... CODEC PACKS ARE THE DEVIL.
Odds are the crap that Nimo installed can never be gotten rid of entirely.
- Gurm -
hahaha this guys a bug out. lolOriginally Posted by Gurm
An all in one guide for DVD to CVD/SVCD/DVD by cecilio click here--> https://www.videohelp.com/forum/userguides/167502.php -
If the guy has xp, then he should try using the resore point feature. The resore point function is crap, but it probabally will work.
Code paks are OK if they are the right ones. I forgot which one I use, but will look when I get home.
Nimo is not the best, and yes, it can screw up a system. Not permanently of course.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
Reconverting Divx videos to smaller Divx files.. strange resolution
By arcooke in forum Video ConversionReplies: 2Last Post: 19th Jul 2011, 02:35 -
Beta Announcement: DivX Plus Web Player 2.1, DivX HiQ and HTML5 Support
By porfitron in forum Latest Video NewsReplies: 1Last Post: 23rd Nov 2010, 12:20 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 18:59 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 17:25
