I'm using a WinTV-Go card, and its great except that I'd like to capture at 720X480 in order to make either higher quality SVCDs or DVDs
My computer is a pentium III, 500 mHZ
Could you recommend a good, inexpensive card that works well with Virtualdub?
Thanks.
Leadtek TV2000 XP deluxe. I got it for $52 shipped from newegg.com.
Regards
Dominic -
AVerDVD EZmaker PCI capture card and packaged NeoDVD Standard software, $40 from CompUSA (sometimes on sale for $10 after rebate).
I see CompUSA now lists the Aver card at $50 and you can check it out here http://www.compusa.com/products/product_info.asp?product%5Fcode=296679&csearch=&cmid=&pfp=srch1 -
i cant comment on the aver card but I have the 2000xp and it caps in 720x480 with great quality. I had a few audio sync problems but that could be machine specific.
It's probably not worth buying another capture card until you can upgrade your PC. You're going to have a difficult time capturing full-frame video with a 500mhz P3 without some kind of hardware encoder. If you're using Win95/98/NT4/2000 (not XP) one thing to do is to buy a used Matrox G400 TV off of eBay. It does mjpeg encoding on the board so you don't need a fast PC. I used to use that board on a 450mhz AMD K6-III and it typically ran only 20-30% CPU utilization capturing full-frame video to mjpeg. It has an excellent TV-out.
I second that. Cheap card usually means the CPU does most of the work.
But, not only you need a fast PC (1500MHz+) but also a big fast disk (80GB+ Ultra DMA 100/133) to be able to sustain the data tansfer rates needed for full D1 resolution capture.
As for cheap cards, I suggest the MSI TV@nywhere. -
Georgeo57 you could get you self WinTV-PVR 250 then you keep your system and do 720x480 or 576 with REALtime MPEG2 Hardware Encoder
Check out CircuitCity there on sale $100 after $50MIR
http://slickdeals.net/?pno=3457&lno=1
I would add a bigger harddrive if I was you 10GB is not very much
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
Why DVD (720x480) bigger than AVI(720x480)
By psxiso in forum Video ConversionReplies: 6Last Post: 3rd Feb 2008, 06:50 -
Anyway to capture 720x480 using the Gamebridge and still play?
By Mysteriouskk in forum Capturing and VCRReplies: 0Last Post: 19th May 2007, 14:07 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
