does it matter if udf or iso mode is used? what's the difference?
Hi,
From my limited experience. I've noted that UDF DVDs can take files that are greater then 2Gigs whereas the DVD-ISO format cannot. I've also found the ISO format to be more compatible then UDF in some DVD players.
Cheers,
feeras -
I use ISO with Joliet if it's just data.
Dowloading Stuff to DVD-R
By Meroko26 in forum Newbie / General discussionsReplies: 5Last Post: 6th Dec 2011, 15:26 -
I want to put my VHS stuff on to DVD
By GianRoss in forum Newbie / General discussionsReplies: 23Last Post: 15th Mar 2011, 13:02 -
Can a DVD recorder record stuff from AV?
By xtube in forum Newbie / General discussionsReplies: 1Last Post: 12th Apr 2010, 08:29 -
What happens when you 'delete' stuff from a DVD before writing to DVDR
By mtdg in forum DVD RippingReplies: 9Last Post: 7th Nov 2008, 09:51 -
Will a dvd burned to be divx ultra be playable(not with enhanced stuff)
By Onceler2 in forum Video ConversionReplies: 2Last Post: 18th Aug 2008, 22:07
