Just wondering if anyone can help me with this error. I have been going through the steps that wizeman posted to convert an SVCD to DVDand all was working perfectly. The first disc of the SVCD had no problems and when burned to a DVD I am assuming will play properly as Apple DVD Player plays it fine...The second disc however comes up with this error when I mux as DVD....I REALLY need to get this film to DVD, so if anyone can help, it would be much appreciated...
I have searched the forums and not found an answer to this problem ... maybe I just missed it, but I don't think so
Here are my Computer specs and the error message I get below...
Computer:
Powerbook G3/500 Firewire (Pismo)
768M RAM
12Gig Internal HD
180Gig External Firewire HD (8M Cache)
Teac CD-W524E (CD-RW) Firewire
Pioneer DVR-106D (DVD-RW) Firewire
I have over 2G of free space on the internal HD and around 100G on the external HD...
ERROR MESSAGE:
% pbpaste | sh
INFO: [mplex] mplex version 2.2.1 ($Date: 2002/04/20 19:08:30 $)
INFO: [mplex] File /Volumes/180Gig/Projects/BowlingForColumbine/GUMBY/tcf-bfcb.mpg-0.m2v looks like an MPEG Video stream.
INFO: [mplex] File /Volumes/180Gig/Projects/BowlingForColumbine/GUMBY/tcf-bfcb.mpg-0.mp2 looks like an MPEG Audio stream.
INFO: [mplex] Found 1 video streams 1 MPEG audio streams and 0 AC3 streams
INFO: [mplex] Selecting DVD output profile (INCOMEPLETE!!!!)
INFO: [mplex] Scanning for header info: Video stream e0 (/Volumes/180Gig/Projects/BowlingForColumbine/GUMBY/tcf-bfcb.mpg-0.m2v)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 480
INFO: [mplex] Frame height : 480
INFO: [mplex] Aspect ratio : 4:3 display
INFO: [mplex] Picture rate : 29.970 frames/sec
INFO: [mplex] Bit rate : 2450000 bits/sec
INFO: [mplex] Vbv buffer size : 229376 bytes
INFO: [mplex] CSPF : 0
INFO: [mplex] Scanning for header info: Audio stream c0 (/Volumes/180Gig/Projects/BowlingForColumbine/GUMBY/tcf-bfcb.mpg-0.mp2)
INFO: [mplex] AUDIO STREAM:
INFO: [mplex] Audio version : 1.0
INFO: [mplex] Layer : 2
INFO: [mplex] CRC checksums : yes
INFO: [mplex] Bit rate : 28672 bytes/sec (224 kbit/sec)
INFO: [mplex] Frequency : 44100 Hz
INFO: [mplex] Mode : 0 stereo
INFO: [mplex] Mode extension : 0
INFO: [mplex] Copyright bit : 0 no copyright
INFO: [mplex] Original/Copy : 0 copy
INFO: [mplex] Emphasis : 0 none
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 2729200
INFO: [mplex] target data-rate specified : 10080000
INFO: [mplex] Setting specified specified data rate: 10080000
INFO: [mplex] Sectors = 89 Video delay = 13019 Audio delay = 13019
INFO: [mplex] New sequence commences...
INFO: [mplex] Video e0: buf= 237568 frame=000000 sector=00000000
INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=00000000
++ WARN: [mplex] End of component bit-stream ... seeking next
++ WARN: [mplex] Failed to find start of next stream at 23925761 prev 23925028 !
++ WARN: [mplex] Failed to find start of next stream at 23926491 prev 23925761 !
++ WARN: [mplex] Failed to find start of next stream at 23927221 prev 23926491 !
++ WARN: [mplex] Failed to find start of next stream at 23927951 prev 23927221 !
++ WARN: [mplex] Failed to find start of next stream at 23928681 prev 23927951 !
++ WARN: [mplex] Failed to find start of next stream at 23929411 prev 23928681 !
++ WARN: [mplex] Failed to find start of next stream at 23930141 prev 23929411 !
++ WARN: [mplex] Failed to find start of next stream at 23930871 prev 23930141 !
++ WARN: [mplex] Failed to find start of next stream at 23931601 prev 23930871 !
++ WARN: [mplex] Failed to find start of next stream at 23932331 prev 23931601 !
++ WARN: [mplex] Failed to find start of next stream at 23933061 prev 23932331 !
++ WARN: [mplex] Failed to find start of next stream at 23933791 prev 23933061 !
++ WARN: [mplex] Failed to find start of next stream at 23934521 prev 23933791 !
++ WARN: [mplex] Failed to find start of next stream at 23935251 prev 23934521 !
++ WARN: [mplex] Failed to find start of next stream at 23935981 prev 23935251 !
++ WARN: [mplex] Failed to find start of next stream at 23936711 prev 23935981 !
++ WARN: [mplex] Failed to find start of next stream at 23937441 prev 23936711 !
++ WARN: [mplex] Failed to find start of next stream at 23938171 prev 23937441 !
**ERROR: [mplex] INTERNAL ERROR: additional data required but no free space in input buffer
Thanks in Advance for any help
-Raisputin
Results 1 to 1 of 1
.m2v outputs from ffmpegX won't compile in DVD-SP 4 (internal muxer error)
By bbartley9 in forum ffmpegX general discussionReplies: 4Last Post: 21st Aug 2010, 04:57 -
Muxing problems with ffmpegx
By Themroc in forum Newbie / General discussionsReplies: 0Last Post: 5th May 2009, 20:49 -
trying to convert AVI to DVD. mplex error. Cannot find .mpa file?
By anarchyx34 in forum ffmpegX general discussionReplies: 8Last Post: 14th Sep 2008, 20:14 -
Winsubmux error. Plus submux not muxing
By Codecoder in forum Authoring (VCD/SVCD)Replies: 1Last Post: 12th Jul 2008, 23:30 -
svcdvd problem, mplex error
By randomtool in forum ffmpegX general discussionReplies: 1Last Post: 26th Sep 2007, 11:49
