  1. Hi all,
    I am in the middle of making my first dvd from a vcd. I have got to the stage where I need to convert my large mpeg file into a DVD format. I tried to use Main concept but couldnt find a download.
    Does anybody have a good link to a guide showing another encoder, once i have done this i can burn it but i need help first.
    thanks
  2. 1) are you trying to convert your VCD to a DVD compliant MPEG-2 so you can make a standard, compliant DVD?
    or
    2) are you trying to burn your VCD onto a DVD without converting (i.e. VCD-DVD)??? this doesn't require you to re-encode, but the compatibility goes down.
    for (1) go here: http://ness888.users.btopenworld.com/fromvcd2dvd.htm
    for (2) go here: https://www.videohelp.com/vcddvdr.htm
  3. Hi Poopyhead,
    Thanks for the response.
    I really want to make DVD-Video. From what i can gather this is the best version to make.
    Do you have any dummy guides that i could follow to do this. Basically i want to go from 2 VCD disks to DVD. I have tried a TMPGenc program to join the files but i cant get it to work. any other ideas what i can use to join and then encode to dvd compliant format?
    thanks
  4. I have similar question!. I have mpeg 1 file on my HD used tmpgenc to convert to mpeg2 but it output 2 files mpg(video) and avi (audio). I convert it to DVD. Could anyone has suggestions!
    Thanks!
  5. did you follow the first link i gave you??
    it's pretty self explanatory
    @tyders,
    how does tmpgenc not work in joining your VCD files??? can you be more specifc. the guide i linked to is pretty clear on how to join the files using tmpgenc's MPEG tools
    if you would rather use tmpgenc to encode to DVD compliant MPEG-2, try these guides..they're not specifically for VCD->DVD, but you should be able to adapt them to your needs.
    https://www.videohelp.com/tmpgencdvd.htm
    https://www.videohelp.com/mpeg2tovcd.htm
  6. @poopyhead
    u r great!
    I followed the link, followed step by step instructions and succeeded in converting 1 vcd to dvd. This was the link I follwed.
    This is a great forum with lots of help!
  7. @gizmofanv,
    np...
    you should thank ness888 for writing the guide.
