SVCDDVDMPG+ v.10.1298.34001
I have done 20-30 single svcd using svcddvdmpg+ with no problems.
now trying to put 2svcd on one dvd with a menu, everthing goes fine all the way up to when its going to author & create the vobs then after the 1or2 vob the system crashes/computer locked up
any ideas?
thanks Lukemon
never seen this b4. What is the file size of the video_ts.vob file?
Can you try the 2 svcds individually to see if the sources are ok?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Duh, one was pal the other was ntsc. then I used mainconcept mpeg encoder to rencode the pal file to ntsc then used svcvdvdmpg+ to process
both onto one file with 2 vts menu, burned with nero, then when dvd played no menu just the movie & it played about 10seconds then restarted again at begining then fast fowarded then hit play then the second movie started.burned with -rw going to reburn to see if this happens again.
Encore DVD Menu Authoring
By montgal in forum Authoring (VCD/SVCD)Replies: 4Last Post: 29th Apr 2012, 23:24 -
Authoring DVD without a menu?
By Humptydank in forum Authoring (DVD)Replies: 6Last Post: 29th Mar 2010, 16:55 -
Which dvd authoring software should I use? IFOEdit keeps crashing.
By architectofpain in forum Authoring (DVD)Replies: 4Last Post: 4th Aug 2009, 05:54 -
dvd authoring with hidden menu
By VeryNewbie in forum Authoring (DVD)Replies: 1Last Post: 21st Jun 2007, 03:21 -
DVD Authoring: Menu Creation, Encoding, etc
By kerpal in forum Authoring (DVD)Replies: 7Last Post: 20th May 2007, 18:27
