When I go to the author tab and I reorder the vcd files, from bca to abc, it encodes it in the original order listed...bca. I've tried Reset/update but that just puts it to bca. Any ideas?
Simplest method would be just to rename the files so they are in the right order to start with.
Not bothered by small problems...
Spend a night alone with a mosquito -
Guest
The thing is, they are already ordered right by name. for some reason b comes before a in the listing. It makes no sense.
Mmm - doesn't for me. Anyone else reproduce this? What build are you using?
Check your file name:1st file- xxxx abc, 2nd file-xxxxbcaOriginally Posted by snek11
the 2nd file will go first because the is no space after xxxx_bca -
Hi, they are already ordered correctly abc etc. I renamed it 1,2,3 to make sure and it does the same thing. The only thing I noticed is the modified date order is 2,3,1 and it seems to go by this. But even reordering them in the program does nothing.
reorder streams with ffmpeg issue
By MarquisdeOz in forum AudioReplies: 6Last Post: 9th Jul 2011, 14:19 -
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
