does anyone know which dvd authoring software does the fastest encoding from mpeg files??
are you talking about encoding avi files into mpeg-2, or talking about compiling the authored dvd?
if you are referring to encoding to mpeg-2, I would not recommend using an authoring program to encode - get a dedicated encoder, it will give you more control and better results overall.
if you are talking about compiling time for an authoring project, DVD Lab takes about 6 or 7 minutes for a full disc with 6 or 7 scene selection menus and 25-30 chapters.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
The fastest program I know of would be NeoDVD Plus http://www.mediostream.com/neodvd/index.html
using iso buster i have ripped svcd mpeg2 files and i want to convert them to a pal dvd with resolution 720 x 528 the problem i am having is i have tried to convert the mpeg-2 files using mainconcept mpeg converter the porblem is when i convert about 2 thirds into the conversion it freezes thinking it might have been a bad rip i re ripped it but i had the same results i even did a check for bad frames but there was no luck there i didnt find ne bad frames.
so i cut one of the mpegs to a small file size about 50 megs and at around the same protion of the conversion the freeze happened again so my problem was finding a suitable converter which i havnt been able to do so gfar so i though about trying to find and authoring package that will do this for me
i tried u lead dvd moviefactory but it doesnt change the video bitrate which main concept allows me to do
im really stuck any hep would be appreciated
and i really dont wanna you svcd2dvd coz i dont wanna convert that way -
DVD Authoring package that will allow forced (hard encoded) subtitles
By netmask56 in forum Authoring (DVD)Replies: 9Last Post: 3rd Mar 2012, 13:27 -
Whats the fastest single system setup for encoding right now?
By x2x3x2 in forum Video ConversionReplies: 0Last Post: 15th Aug 2011, 05:08 -
Noob Encoding Package
By darkdream4 in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2010, 15:44 -
Complete Authoring Package please?
By 1RealNewbie in forum Authoring (DVD)Replies: 3Last Post: 28th Sep 2009, 08:09 -
Can someone recommend a good package for editing/authoring?
By bek in forum Authoring (DVD)Replies: 2Last Post: 31st Mar 2008, 17:20
