I have following known codes
* MJPEG-1 Codec
* MJPEG-2 Codec
* DivX MJPEC-4 Low-Motion
* DivX MJPEC-4 Fast Motion
* Huffyuv v2.1.1 – CCESP Patch v0.2.2
And I have these unknown codes
* Windows Media® Video Compression
* DV Video Encoder
* Indeo video 5.10 Compression Filter
* Ligos GoMotion Analog to MPEG Filter
* Ligos GoMotion DV to MPEG filter (ver 1.7)
* MJPEG Compressor
* Cinepak Codec by Radius
* Intel 4:2:0 Video V2.50
* Intel Indeo Video R3.2
* Indeo video 5.10
* Microsoft H.261 Video Codec
* Microsoft H.263 Video Codec
* Microsoft MPEG-4 VKI Codec V2
* Microsoft MPEG-4 VKI Codec V3
* Microsoft MPEG-4 VKI Codec V1
* Microsoft RLE
* Microsoft Video 1
* TechSmith Screen Capture Codec
* VFAPI Reader Codec 1.03
Where can I get some basic info about these unknown (to me) codes?
Is there any good codec which I can make use of? I tried the MJPEC, but I am not able to configure and I am not able to open the AVI with TMPGEnc.
Any help or pointers are much appreciated.
REgards
Dominic
Dominic, a lot of those are just standrd Windows installed codecs. I recognize a lot of them. There used to be a site called www.fourcc.org but I don't know what happened to them. This page should get you started: http://www.am-soft.ru/fourcc.html
I have a 64bit system, to encode files do i need 64 bit codecs?
By shadowofanubis6 in forum Newbie / General discussionsReplies: 5Last Post: 1st Mar 2010, 11:24 -
Hardware or Software codecs for Starnet Development ad insertion system
By cybertheque in forum Capturing and VCRReplies: 3Last Post: 9th Mar 2009, 12:48 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 15:29 -
New System with Vista- Need codecs...
By 4194 in forum Software PlayingReplies: 17Last Post: 21st May 2008, 03:51 -
Application to View Codecs that are Installed on Your System
By JBredensteiner in forum Newbie / General discussionsReplies: 4Last Post: 23rd May 2007, 01:58
