I made a video of a team I coach, and have successfully burned it to DVD using iMovie/iDVD. My question is, once I burn it to DVD, can I delete the original files but be able to make copies of the DVD I burned in case I want to make additional copies for the other players? If so, how would I do that? Can I rip it with other software, like DVD21?
1. since you burned it already, as long as you are comfortable with your burning and happy that your disk is working properly, you can toss the origional. However, if you are going to make copies immediatly, keep the source until all copies are made.
2. since you made it, its already on DVD-5 format, so there is no extra steps required other than copying it back to yoru HD from the disk use OPTION-DRAG (i think) to copy the disk back to your desktop. then just burn it using toast or disk copy.
3. dvd2one isnt a ripper. its a compressor, taking dvd9 down to dvd5 so you can burn it. If you want, you can use DVDBackup 1.3 to RIP your already made disk back to yoru HD, but its no different than copying it (since you made the disk yourself)
If it were a commercial disk you were backing up, you woudl have to use DVDBackup to get it to your HD then DVD2ONE to make it DVD-5 -
Apple''s method of copying an iDVD created disk: use the create image from device choice in Disk Copy, selecting the CD/DVD master option in the pop-up menu in the save dialog, then after the image is created, burn the DVD with the burn image command in the file menu.
Another method would be to use DVD Imager.
http://lonestar.utsa.edu/llee/applescript/dvdimager.html
Need advice to make my own home video/DVD
By Vidnewbie1 in forum Newbie / General discussionsReplies: 5Last Post: 29th Jun 2010, 13:30 -
Copying some home video on VHS to DVD
By syilim in forum Newbie / General discussionsReplies: 1Last Post: 4th Nov 2008, 22:23 -
Home Video to DVD no sound
By nixacrew in forum Newbie / General discussionsReplies: 2Last Post: 2nd Feb 2008, 12:06 -
Nero 8, Plextor PX716A, PX116A and copying DVD+R (home movies)
By alokeprasad in forum Authoring (DVD)Replies: 0Last Post: 30th Dec 2007, 09:26 -
Problems copying a home-made DVD
By jj1807 in forum Authoring (DVD)Replies: 3Last Post: 2nd Jul 2007, 15:20
