I have a PAL SVCD and I am trying to burn as a DVD-SVCD. I have converted the sound and all of that, but I when I get to changing the header, the verticle size is 576, PAL format. And the frame rate is 25 fps, PAL format. Could I burn with with moviefactory 2 under the NTSC settings in the program and have it come out right and play on my DVD player? I already burned it as a SVCD and it played right, so would burning it in MF2 under the NTSC settings be fine? Thanks.
I doubt it.Originally Posted by syxx2001
You'll probably need to convert the MPEG source file, itself, to conform to NTSC.
Jerry Jones
http://www.jonesgroup.net
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
NTSC -> PAL same movie length?
By busta3396 in forum MacReplies: 5Last Post: 6th Mar 2010, 07:30 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19 -
Is “Movie Clone 4 Gold” capable of converting PAL into NTSC?
By coody in forum DVD RippingReplies: 3Last Post: 5th Dec 2007, 17:39
