I have a question about virtualdub frame rate setting. Do you input the frame rate in frames per second or in seconds per frame?
Example:
NTSC is 29.95fps but virtualdub shows the frame rate in milliseconds. Does this mean that you would convert 29.95fps to 1/29.95 or 33.38ms? I would just like to know what the setting should be set to for NTSC.
pettinej
Not sure where your looking. Individual frames can display their length ( in ms). VDUB should be in fps. with 60/30/29.97/25/23.96/20/15/12.5 being common button settings.
To Be, Or, Not To Be, That, Is The Gazorgan Plan
Convert framerate?
By stuar.t in forum Newbie / General discussionsReplies: 12Last Post: 18th Feb 2012, 16:54 -
Converting a "variable framerate" to constant framerate?
By vieo in forum Video ConversionReplies: 6Last Post: 2nd Sep 2010, 10:05 -
How do I convert xvid framerate 23,967 to xvid framerate 25.000?
By QuickstartDK in forum Newbie / General discussionsReplies: 16Last Post: 4th Nov 2009, 18:57 -
i need a framerate converter
By snafubaby in forum Newbie / General discussionsReplies: 6Last Post: 11th Dec 2008, 22:44 -
Framerate Problems
By InvincibilityCloak in forum Video ConversionReplies: 1Last Post: 26th Mar 2008, 16:17
