  1. OK - I am trying to create a DVD with dual sound - german / english - so what sound format would you suggest to incooperate for this - the sound should be switchable , no need for menu switch a simple remote switch will do just fine , and how would you do this ??
  2. Go for AC3. It takes less space and it's more compliant.
    Enjoy!
  3. Hey Gregg , thanks for your answer .
    I did convert them with besweet to ac.3 but how will i get them now together with the film ??
  4. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    you will need software that supports multiple audio streams.
    the cheapest one I know of is ReelDVD ($600??) from Sonic. I've heard that either DVD Wise or DVD Junior supports, but I have no experience with either of them.
    Check the Tools section under DVD Authoring.
    there is also a workaround to get DVD Lab to author existing vobs with multiple audio streams that you create with IFOedit, but I am totally lost when I look at that program... there was a guide or thread on it that I saw recently, if I can find it I'll link to it here.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
  5. Hey housepig , first of all thanks for your answer -
    but if you look at this than you might know more
    https://www.videohelp.com/forum/viewtopic.php?t=170642
    thx michaelny
