I have some MPEG1 files wich i want to burn with IDVD, Thet can not be imported in IDVD or Imovie. I can play them in Quicktime but cannot export them from Quicktime Pro because it says that there is no audio track. Anyone knows how to convert this file to a usable video/sound file.
(mpeg info: Mpeg 1 system file (video/audio), Muxrate 1.41mbps, size 253x240, 29,97fps, 1.15Mbps, Audio Mpeg 1 layer 2, 224kbps, 44100 HZ, stereo no emphasis)
I have the same problem, and i dont want to demux and then rejoin etc etc... surely there must be a simple way, as I have tried many of the tips in this forum... and simply dont have the time to convert 200 cartoons.
Sorry, but the only way the I know of is to demux them, then convert.
just a heads up, that the resulting video after idvd will probably look really bad.
demux with ffmpegx or missingmpegtools, then convert the mpeg video to .mov through qt pro, covert mpeg audio to aiff, join audio video, add scaled in qt pro. this should work. havent done something like this in a long time so a step might be missing.
if you can get dvd studio pro (dsp) you can author mpeg 1 video in it. maybe wait and see if toast 6 will make dvd's w/ mpeg 1 video. if you have that many. but i'd only do one and a short one just to test to see if you even like the resulting quality. i htink it'd look better to just keep it as a vcd. unless somehting like sizzle can handle mpeg1's or what about trying to author the mpeg1 as dvd with ffmpegx or missing mpeg tools??pants on, pants off, pants the floor.
QuickTime MOV to MPEG2 too dark
By bgtrix in forum Video ConversionReplies: 1Last Post: 16th Mar 2012, 11:36 -
Best .mts to Quicktime .mov converter?
By nojiri in forum Video ConversionReplies: 3Last Post: 28th Jun 2010, 18:54 -
Is there a way to normalize a .mov file in Quicktime ?
By abrand88 in forum Newbie / General discussionsReplies: 1Last Post: 23rd Apr 2010, 12:03 -
I can't edit this mov quicktime file
By qisheng in forum EditingReplies: 19Last Post: 1st Dec 2009, 03:05 -
quicktime (.mov) conversion
By superstarx85 in forum Video ConversionReplies: 0Last Post: 11th May 2007, 04:10
