Help i have a lot and avi (divx) movies
But the are the wrong resolution how can I make them rady for vcd or svcd??
I need a program that can convert the avi's to mpg and also make them the right resolution??
I have tried TMPGEnc but it reports invalid or unsupported((
Can any one help me
I have also some smaller peaces like 10 mb I can send you if you want to see what I mean)
BG
Results 1 to 18 of 18
http://www.vcdhelp.com/tmpgenc.htm
Read the guide, please. Source aspect ratio 1:1 VGA, full screen/keep aspect ratio. -
ahh i dit not explain right
i have downloadet a lot of avi movies (divx)
now i want to make them on to a vcd or svcd
but the are the rong resulution
how can i made the rady fore vcd???
BG -
I am pretty sure, the resolution of the divx does not matter.
If TMPG reports "..can not open or unsupported", you have to install the proper codec. -
is it a special code for the
tmpgenc ????
and what is the excat url for it??
THX
Bg -
Can you play the divx with windows media player? If yes, OK. If not, you have to install the divx codec, that was used to compress the avi.
In TMPG select option> enviromental setting > VFAPI and set Direct show multimedia file reader to highest priority.
You can encode avi with any resolution to mpeg. All what you have to do, is to resize as I said above.
If TMPG still not open the file, it is probably corrupt.
Then check the tool section for DivXfix or something like that.
yes i can see divx
but i re installed all codes just to be sure
and now it is vorking
Thank You so much
now i have a new problem
i re encodet a lot og my avi's
some are vorking fine, but in a few
the audio dos not follow the movie
Du you know how I can fix that?
Is there some audio sync program or some thing ??
BG
ohh also i have set the perorty to 1 in the 2 you said to me
all others are set to 0
is that right?? -
... but in a few
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Is the audio simply not matching the video or is the video/audio faster than audio/video?
Did you notice that, when playing the MPEG or when playing the AVI? -
in the avi
the audio is okay
all is good
in the mpg i made the audio is faster than the video i think
it is like the audio start plauying a littel before the video and it keeps that way all movie long
but only in the mpg!!!
the downloadet avi is 100 % okay
what can i do??? -
ohhh and by the way
i have made 3 other encodings other movies
they are all fine
only some of thise danish videos
(( in pal
BG
I heard (well, I never had that prob), that a simple demux/remux solve the problem.
http://www.vcdhelp.com/bbmpegedit.htm -
well it dit not solve the problem by it selv
i hade to chanbge the audio delay from 344 to 2044
wow so rong it was humm i dont understand
and i have to serch for the right audio delay for like 2 houers
is there no other app that can do this more easy?
like adobe primere can it do it??
or some other program
i think a program that can play the file an i can just adjust the audio speed to mach.. and after that just chlick reencode or some thing like that
but any way thanks for the help
i lernd a lot from this
now i only have to master how to make a real good and real good loking dvd rip to svcd or vcd
and hot to convert a good avi to a real good svcd or vcd
cya
BG -
When you use TMPGenc are you "loading" a VCD template. Also have you scanned the AVI's for bad frames ?
If the AVI is playing without problems, then converting to VCD.mpeg using a template in TMPGEnc will cause no problems, unless the AVI has bad frames.
Use "vdub-mp3-freeze.exe" to scan AVI for bad frames.
vdub-mp3-freeze.exe
hummmmmm
year so how and how and ware and so on
i dont eaven know what vdub-mp3-freeze.exe is
BG
but thanks for the try *lol* -
Any suggestions on what filters and "soften block noise" settings could be used to reduce the blocks?
temperal noise reduction i believe.
also set motion estimation to it's highest aka slowest setting. -
Is there any site that has detailed explainations of the filter settings?
ac3 avi movies don't play back in 5.1 on divx dvd player
By funkyspaceman in forum AudioReplies: 10Last Post: 22nd Oct 2015, 17:01 -
Can the PS2 play divx avi movies?
By amjad_z4 in forum DVD & Blu-ray PlayersReplies: 30Last Post: 14th Jul 2010, 06:52 -
How to put a lot of movies into single DVD
By TheEmperor in forum Authoring (DVD)Replies: 9Last Post: 19th Sep 2009, 12:48 -
Divx (.avi) movies with 5 sec audio delay - can these be saved?
By Hank Kinsley in forum Newbie / General discussionsReplies: 2Last Post: 19th Nov 2008, 23:20 -
Burning Divx movies with subtitles?
By Hank Kinsley in forum SubtitleReplies: 5Last Post: 17th Jul 2007, 12:33
