    Jul 2003
    Germany
    Hi Folks,
    i'm an newbie in the linux theme video producing...
    In WinXP i use the powerfull and easy usage tool
    (s)vcd2dvdmpg (This Tool patches (S)VCD MPEG Streams
    and resamples the Audio Channel from 44.1 zo 48.0 KHz,
    then it creates VOB Files with Menu and chapters
    Links between the MPEG Streams creates this tool same.
    Then you can burn the Audio_ts and Video_ts Folder with
    an Burn Progamm, that understand UDF DVD.
    My Question now is.
    Which Way i must go, to use the same Features in Linux,
    without Installing VMWare or Switchboot WinXP ?
    Many Thanks for powerfull and professional Tipps.
    greetings
    Alex
  2. Hi i'm a Linux fan since 1996 ... in recent times many improvements have been made in "multimedia" field.
    Anyway to give an unbiased opinion Windoze VIDEO software is the most advanced and user-friendly.
    But don't worry ... you can try to enjoy yourself with these tools:
    http://freshmeat.net/search/?q=svcd&section=projects
    See ya!
    Rock ON!
