I have downloaded 28 days later dvd rip, and have extracted the files so that i have two seperate folders - cd1 and cd2 , each one containing a BIN file and a CUE file. My question is - how do I go about either burning these to a CDr using my DVD Copy Plus program, or simply watching them on my computer dvd drive?
Import them into a progamme called Isobuster.When the file is imported ,right click on mpeg2 part of the file and extract (middle one of the extracts options).It will extract to a file ,when it has finished rename the file (the movie name) then .mpg and theres ur file which u can watch then do the same to cd2.
Hope this helps. -
Hi,
You can burn .bin/.cue files with many recording programs (Nero, CDRwin etc.) just burn the image to a recordable (or rewritable) cd and it should play fine in your pc.
Another option is to download/install Deamon Tools and 'mount' the image. This way you can play the image of a virtual drive, which is much faster and doesn't require you to use a recordable/rewritable.
Greetz,
pSyChO dAdThe difference between genius and insanity is only measured by success ! -
thanks a lot guys, i tried the isobuster route and had success watching the file...if only i could burn it so that its watchable on a standard dvd player..
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
extracting the bin/cue from .oo1,.002 etc files
By belwas in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2010, 01:59 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 07:06 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 10:11 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29
