I was told you have to have a DVD burner to burn VCD, SVCD movies onto a cd? Is this true. Im going to be use cd-r. If not do i have to have a DVD burner when using DVD cd's?
you can use a dvd burner to burn cd. but guess what a cd burner can burn.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
OK, i said it wrong.
Here: Do you have to have a DVD burner to burn cd-r/cd-rw. If you don't can you burn a dvd-r/dvd-rw with just a cd burner? -
sorry...i am totally confused...anywayz...here goes:Originally Posted by nempo
a DVD burner can burn both DVDs and CDs
a CD burner can ONLY burn CDs -
I'll type very slowly...
with a cd burner, you can burn cds. this includes vcd, svcd and miniDVD (an out-of-spec format, but possibly playable on your machine).
if you want to burn dvdr, you need a dvd burner, which will also burn all of the above.
you can not burn a dvdr on a cd burner.
does this clear it up?- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light"
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 06:27 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 15:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19
