I usually use DVDShrink 2.3 to shrink the movies. Now this movie is broken down into
Menus 121MB
Main Movie 4,229MB
Extras 1,864 MB.
Now i want to get rid of the extras and keep the main movie and menus. How do i do that.
Thanks,
not with DVDshrink...
if you get rid of the extras, you will also need to remove the menus. this is re-author mode.
otherwise, you can use backup mode and just turn the extras into still images...that's the highest compression...basically renders the extras not watchable..however, they still take up space. -
Clone DVD has the nice feature of making movie only backups while still retaining the menu. give it a try.
CloneDVD = Cooooool.
Combine it with AnyDVD and you have an AWESOME package.
- Gurm -
Does CLone DVD work with Nero already installed. Also is their a guide for the Clone DVD settings.
Thanks for you help. -
Why wouldn't it?
Oh, wait - you're thinking of CloneCD, not CloneDVD. It sometimes had issues with Nero, yes.
No, CloneDVD has no such problems.
As for "settings", it's not only really simple, but lacking many settings at all.
- Gurm -
I know its
but I have to say the first 5min. of Ghostship have to be the bloodiest five minutes of movie I have ever seen.
Backing up a DVD
By kschwi in forum DVD RippingReplies: 19Last Post: 29th Nov 2009, 09:15 -
backing up footage
By JJJewel in forum Video ConversionReplies: 5Last Post: 25th Oct 2009, 07:26 -
backing up computer
By vipertongn in forum ComputerReplies: 5Last Post: 26th Nov 2007, 12:08 -
Backing up Games?
By LCE in forum Off topicReplies: 2Last Post: 23rd Oct 2007, 23:45 -
'backing up' dvds
By nobbyiscool in forum Newbie / General discussionsReplies: 3Last Post: 13th Aug 2007, 20:25
