Hey guys, I d/led a certain movie separated into 3 parts. Supposedly I should be able to rencode them with TMPGEnc and turn them into 3 SVCDs. However, I noticed that when converting them, the video turned out fine, BUT, the audio would cut out on each new mpeg at about ~10 sec into the flick (and never return).
WTF? Does anyone know why this happens? I've tried different settings for the audio encode portion, but that didn't help. Also the 3 parts play the video/audio fine. It's only the re-encode with TMPGEnc that screws the sound.
From what I can tell, here is how the 3 files are encoded:
Divx Decoder - Divx 5.05
mp3 decoder - 44100Hz, 96 kBits/s
Thanks for any help.
-Robg69
by the way this is "[The Pit]", "SVCD-TS-CTP" release, etc. of that popular movie if that helps anyone.
Also TMPEnc reports this info:
MPEG-2 432x176 25fps CBR 1150kbps, Layer-2 44100Hz 96kbps
ok guys I found this info from bugster:
I'm going to try this and see how it works. Sorry for my post, but I wasn't exactly sure what to search for.If there is no sound on your SVCD, something went wrong BEFORE the encoding stage (assuming you encodeed audio and video together). If your source is avi, extract the audio using virtualdub, use full processing mode, compression=none, conversion to 441000hz sample rate if needed. Then use this wav file as the input to your encoder.
Thanks,
-Robg69
Conversion divx to svcd gives Choppy Playback
By Soixante in forum Video ConversionReplies: 2Last Post: 17th Nov 2009, 07:25 -
Sound lost after conversion mpeg to avi
By maclinux in forum Newbie / General discussionsReplies: 1Last Post: 19th Dec 2008, 14:47 -
DIVX to AVI conversion
By jjbodean1970 in forum Video ConversionReplies: 9Last Post: 18th Aug 2008, 01:05 -
No sound conversion MPEG-TS to .avi
By oli60 in forum ffmpegX general discussionReplies: 2Last Post: 22nd Oct 2007, 01:49 -
riverpast rm to avi conversion sound out of sync
By princevegetam in forum Video ConversionReplies: 9Last Post: 2nd Jul 2007, 03:45
