I demuxed a file with tmpgenc and had a mp2 (audio) and m2v (video) file. I converted the audio to .wav, made some edits in cooledit and then converted to mp3. then used tmpenc to multiplex. i could play the file with winDVD fine. so I used VCDImager to make and image and then burned it. It plays with sound on an Apex player but there is no sound on the Pioneer DV343. I then took the file and demuxed in tmpgenc and it created a mpa file for the audio file (instead of the usuall mp2) and i used bbmpeg to multiplex. the resulting file has no sound (i can tell this by playing in windvd or by just looking at the size of it, it is the same size as the elementary video file before the bbmpeg multiplexing). how should i convert the .wav file so that it will work? isn't it just an mp3? what am i doing wrong? thanks
Nevermind, I skipped through the FAQ too quickly the first time and didn't see the answer.
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 07:36 -
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 12:25 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 18:24 -
ASF2VC1 & transcode the audio WMA to AC3, then mux video VC-1 and audio
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2010, 09:02 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 02:19
