  1. Im just trying to burn a DVD, its small enough to fit on one 4.7 DVD-R. My problem is it gets done copying the data to my comp, then I put in the DVD and its only burning about 1/4 of the whole thing, then saying its done..... I can't keep trying over and over since DVD's cost a bit
    Anyone know what this could be?
    Oh I'm still lost about how to burn a DVD that needs two disks with DVDxCopy express.
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    did you check here in thier support forum ? http://dvdxcopy.afterdawn.com/
    its a known problem - so keep updating to newest version ..
  3. addressing your second question:
    dvdxcopy xpress will automatically compress the dvd-9 to fit to one dvdr.
    just simply press start and let it do its thing, then when its done it will give u the option to burn it. Its very very simple.
  4. thanks for the help!
