I HAVE BEEN TRYING TO EDIT THE SOUND ON DVD'S AND FINALLY DID IT SUCCESSFULLY. THIS IS HOW I DID IT, SINCE I AM NEW TO THE WHOLE THING MAYBE I WAS JUST LUCKY BUT THIS IS THE SEQUENCE.
1. RIPPED DVD TO HARD DRIVE WITH SMARTRIPPER
2. DEMUXED WITH DVDLAB TO AC3 AND M2V FILES
3. USED BESWEET TO CONVERT AC3 FILE TO WAV
4. EDITED WAVE FILE WITH COOL EDIT PRO ( SILENCED BAD WORDS )
5. USED BESWEET TO CONVERT BACK TO AC3 FILE
6. USED DVDLAB TO LOAD AC3 AND M2V FILES FOR ENCODING
7. AUTHORED DVD TO HARD DRIVE WITH DVDLAB, HAD TO ADD BUTTON AND SET TIMERS, USED 10 SECONDS ON THE THREE SETTINGS.
8. BURNED WITH VERITAS RECORD NOW.
NOW WHEN WATCHING MOVIE WHEN UNDESIRABLE WORDS COME THERE IS SILENCE. :P
Great job dude. Sounds like a lot of work, but I'm sure it was worth it. It's to bad the movie industry does'nt have seperate audio versions with their movies. You don't need foul language to make a good film.
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Instead of silence you could probably insert a slang word into the portion deleted also. I remember seeing a DVD Player (Toshiba I think) that recognized a large number off offensive words and replacing them with slang words .... but I've never heard how successful it was. I bought it but it wouldn't play SVCDs so I took it back. Shame.
"No freeman shall be debarred the use of arms." - THOMAS JEFFERSON .. 1776
How to edit an MKV with MKVMerge and it be successful?
By KingMatt in forum Video ConversionReplies: 1Last Post: 8th Sep 2011, 11:27 -
Try to edit my mpeg but no sound!
By leegundo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 2nd Aug 2010, 10:56 -
Problem with Magix Movie Edit 14 - Sound muted between objects.
By Jo The Veteran in forum EditingReplies: 1Last Post: 3rd Jun 2009, 17:49 -
How to verify a successful encode
By maxxed in forum Newbie / General discussionsReplies: 6Last Post: 8th Feb 2008, 20:31 -
DL problems after successful burning
By m-man in forum Authoring (DVD)Replies: 7Last Post: 9th Jul 2007, 19:53
